Rancho Cucamonga, CA
5/10/2022 6:14pm
Why are shock shaft nuts peened on? Is the theory behind this just making sure it doesn’t back out while riding? Seems like a pain to have to have to grind the threads every time you do maintenance. Why not just use a locking nut and red loc-tite. Seems like that would be plenty.
After that yes red lactate on the nut-depending on who took it apart and quality of the grind
for insurance use a new nut
Use a spot of Red lactate
Have seen nasty grind jobs to get rid of the peen
Is it Showa or KYB?
Post photo of nut
25ft lbs red loctite is what I do.
The metering rod in the shock shaft is stuck so it will not allow bleeding. Stick a small wooden or plastic rod in the hole in the shaft to push the the rod needle down. Make sure your rebound clicker is full CCW soft.
Is rebound backed all the way out?
Make sure by pushing the rod down from top of shaft with small
allen
Click
Post a reply to: Question for suspension guys
