Thompsons Station, TN
6/7/2018 1:18pm
I have heard about the power valves sticking on the 16/17 KTM 125's. Well I was prepping my sons bike Saturday and took it for a spin up the street and I noticed it wouldn't rev out. So I pulled the cover to watch and see If the PV was working and nothing. It finally broke loose and revved out but it was extremely slow to return and the power was erratic. I'm going to take it apart in the next day or so and clean everything but the bike only has 10 hours.
Has anyone else had the issue? If so how did you fix it?
Thanks!
Thanks!
The bottom photo shows the OEM arm(black) vs new arm(gold)made by F1moto.
You can see on the OEM arm there's a flat spot where the sliding pins get stuck on my bike.
I order the new set : http://m.ebay.com.au/itm/192076490596?_mwBanner=1
Hopefully can install mine this week and test them out!
http://www.ebay.ca/itm/KTM125-SX-PERFORMANCE-POWERVALVE-ARMS-2016-2017-…
Edit: Haha CarlinoJoe holeshotted
I wonder if you could just round out the OEM with a dremel?
Another question?
When assembling the Power Valve is it a must to measure the distance of the flap with the tool as shown in the manual? Could I just measure the distance before and after with calipers or does it actually move when taking everything apart?
They also recommend adjusting the deck height with the dial indicator. I was hoping to could measure the current gaskets or do a squish test.
Thanks!
I'm going to test the new arms and I'll try to round out the OEM ones to see if it helps.
I just placed an order last night.
As far as the grinding my friend smoothed out his with a dremel and he said it worked fine. I was going to order the F1 arms to ensure they were right and not chance me grinding a little too much off.
I sent a message to Steve to verify the issue was resolved. After reviewing the pics you can see a difference in the pin location from the OEM.
Second batch due to complete today.
These will be sent out free of charge today to the people who have purchased already.
Thanks Steve!
The riders left I had to shave a hair off the spot where the pin fits into the triangle piece. As seen in this photo.
Movement by hand is much smoother and I don't feel any binding like I did before.
From the response I thought the new ones were not ready?
Usually takes about a week shipping to the US.
Please keep the feedback coming on the revised design.
Thanks in advance.
Probably best to wait for the replacement arms to arrive and base your testing on these.
We know the originals were wrong & have corrected this.
Replacements on the way to all customers.
Regards
Steve
Was there anything else changed on version 2?
Hopefully smooth operation with good performance.Please keep feedback coming preferably by PM.
They felt smooth to the hand, but once in riding conditions they were sticking more than stock. Not sure how bad your stock ones are. I've also replaced the rubber orings on all the moving parts that has to do with the power valve.
Post a reply to: Power valve sticking on 16/17 KTM 125's
