Shenandoah, VA
2stroke153
3/30/2020 6:49pm
3/30/2020 6:49pm
I have a 99 cr125 that I pulled apart to clean the power valves. When I took the covers off theres oil covering everything and literally oil sitting in the pocket where the pinion shaft comes up through. I also have quite a bit of oil leaking out from where my pipe connects to the cylinder. Is this semi-normal? Is it running way rich?? (Plug has good color but really wet). Or do I have other issues? Thanks for help in advance!
Post a reply to: Power valve oil issue??
