Ijamsville, MD
Luke_Richards
5/31/2020 4:32pm
5/31/2020 4:32pm
6/2/2020 9:41pm
I’m have a bit of up and down play in my upper shock bolt, when I take the bike off the stand and put it on the ground and if I pick up on the rear wheel with it on the stand I can hear/feel it. Bike has about 15 hours on it, I have greased the bearings twice in those 15 hours. Bolt is torqued to spec.
how many total hrs on bike?
Hard to believe it needs new bearings already, it’s torqued to spec, and It’s been greased about 3 hours ago. Could
It just be because of the pc link arm? It’s enough play to just be noticeable
Sooo what an effort to register to add my solution if it is one for any of you…. I had this issue a solved it by (if u also have a thread in the nut side) tighten the bolt to spec first without the nut then put the nut on a tighten to same spec! Took all play out … ‘04 KX250F for me btw…
In the upper shock bolt…
Post a reply to: Play in top shock bolt
