Play in linkage YZ250
chump6784
Edited Date/Time 8/23/2017 4:53am
Hey guys, I noticed some free play in my linkage the other day, when the bike is on the stand I can grab the rear wheel and can move it up and down so I pulled it all apart and replaced all the linkage bearings, put it all back together and there is still play in it.
The play seems to be in the part that is attached by a bolt through the swingarm. I am guessing that either the housing where the bolt goes through is worn or the bolt itself is worn. Is there anything else it could be?
CarlinoJoeVideo
Portland/Los Angeles, CA US
2339th
8/18/2017 10:48pm
All my bikes get play in the linkage eventually. I think the swingarm mounting hole gets out of round. It will be interested to hear if there's a fix...
BobPA
PA US
8/19/2017 3:48pm
Most bikes have a bit of play. When my KTM was brand new it was tight. 20 some odd hours later and it moves as much as my 250....with 200 hours (albeit fresh bearings)
Wade221
Yuba City, CA US
8/19/2017 4:08pm
That's the same symptoms of bad swingarm bearings
Additionally, has your shock been serviced recently?
chump6784
8/20/2017 3:36am
I went into the shed and pulled my wife's linkage or of her yz125 and put into my bike and it still had play where it had none in hers. Figured it must have been the hole in the swingarm so i pulled it back out and put it back in her bike. When i did hers all up it had play in it. I figured it was something i was doing wrong. I loosened it off and made sure the bolt through the swingarm was really pushed all the way through, did it up and no play.
I put mine back together making sure the bolt was in properly and the end result was a tiny little bit of play. From the comments above this sounds normal.
Both bikes have around 60 hours on them, the difference is I'm 198 lbs and not afraid of jumps, she's 120 and a real novice
rmoto003
Gulf Shores, AL US
8/20/2017 6:14am
Yea pretty sure this is normal. Every bike Ive had eventually starts having some play, even with all new bearings.
I mean theres what, 6 connections between the shock, swingarm, and frame? A tiny amount of play in each of those adds up
FGR01
AZ US
1222nd
8/20/2017 9:39pm
Did you replace the small needle bearing at the lower shock mount? That is the one that usually gets the most noticeable play.
Junior467
Lake elsinore, CA US
8/21/2017 7:13am
When you torque the bolt is the bike on a stand or wheels on the ground?
seth505
SD, CA US
1092nd
8/21/2017 7:16am
Agree with this. Also, I stand the bike on the ground under it's own weight to torque everything to spec, not fully extended up on a stand.
IceMan446
Sacramento, CA US
8/21/2017 12:26pm
You will always have a little bit of play. Its mainly going to be from the top shock bearing. I think its called a thrust bearing?
But even brand new it will have a small amount of play.
hellion
Westfield, MA US
8/22/2017 9:25am
I seem to go through the needle bearing at the bottom of the shock quite often on my YZ. And if your bike has been off road a bunch, the hole that bearing fits into can actually get out of round too from hitting trees and rocks. I'd suspect you'll find your problem there.
Skerby
Mayes County, OK US
8/22/2017 1:52pm
Upper shock bushing (spherical bearing) is usually the culprit on my YZ250. I have an old dinner plate with linkage remnants about 9" high covered with cling wrap from my YZ racing days, it gets muddy in the PNW!
The primary lessons that are learned back in those days when full linkage bearing replacement was at least a twice per season deal:
1.) Riding mud is the quickest way to wear out link bearings.
2.) OEM stuff is as good as it gets and usually worth the extra cost.
3.) Molybdenum grease is your best option for longevity, the green marine greases get washed out pretty easy.
My .02
chump6784
8/23/2017 4:53am
yep, did the whole lot
chump6784
8/23/2017 4:54am
on the stand, will redo on the ground
hassbeen
Pretoria ZA
3823rd
8/23/2017 5:23am
Did you replace the swingarm bearings, They often have excessive play and require frequent regreasing too. Also noticed the bottom shock bearing wears quickly.
On a side note my Steering head bearings also wear quickly. I think it's a bad design, keen to hear what others have done to alleviate the problem.
Skerby
Mayes County, OK US
8/30/2017 1:19pm
hassbeen wrote:
Did you replace the swingarm bearings, They often have excessive play and require frequent regreasing too. Also noticed the bottom shock bearing wears quickly. On a...
Been through a few steering bearings too. I used the moly grease last time mine was apart and it seemed to have helped keep it from getting worse. I think they just don't seal very well, and a lot of care has to be taken to make sure the seal is in the right place.
Idk if its because of the moly grease, but I've had mine loosen up a number of times. If your bike ever gets really twitchy, this may be the cause lol.
YamahaJT1
VA US
8/31/2017 12:23pm Edited Date/Time 8/31/2017 12:27pm
IceMan446 wrote:
You will always have a little bit of play. Its mainly going to be from the top shock bearing. I think its called a thrust bearing...
Spherical bearing, IIRC...
Good call. All the energy culminates on that little bastard fulcrum. It takes a beating, and many overlook it.
YamahaJT1
VA US
8/31/2017 12:38pm
Skerby wrote:
Been through a few steering bearings too. I used the moly grease last time mine was apart and it seemed to have helped keep it from...
Ya know what?
I have thought of tapping a zerk into the lower yoke and a relief valve into the upper yoke. Fill that biznatch with calcium sulfonate grease until it comes out of the relief valve.
Just don't quite have the nads to do it yet.
Post a reply to: Play in linkage YZ250
