DK
7/3/2020 3:09am
Hello,
I just did a piston change on my 250yz which have done 80 hours total. It started first time and went racing no problems... But
It has this ping or ding sound and I don’t think it made this sound with the old piston... I think it might be because of the better compression, but not sure.. my buddies said that it did not sound like any motor problems at all, but I’m still a little nervous :/ have anyone tried this before?? Tried to repack muffler and did little to nothing.. it sounds like it’s coming from the front pipe (don’t know the English name)
https://youtu.be/IhHTsXnJHi4
Tried recording the sound..
Hope someone can help :/
These engines are built with a squish issue right from the factory and cause problems and then if an after market unit is introduced it can cause even more issues.
Do you see any pitting on the edges of the new or old pistons?
Dont richen it for the sake of longevity and cost performance , but put the right fuel in and you will get performance and safety.
Yes try that 100octane with less ethanol.
I’m thinking either your base gasket is thinner, or your piston compression height is taller.
Here is a picture of the piston! Just Remixes the top end and did 40 min of Racing with the pinging! I Think it looks totally fine
Post a reply to: Pinging after piston change.
