Hi i had a bad crash last year with my bike and after the crash the bike wont start...there is no spark at the coil,the injector wont pulverise but the fuel pump works i mesure the 2 ckp sensor and the resistance is 240.8ohm and the alternator does give 12V because i tried it with a 12V light bulb and it fires...I check the regulator and the numbers are the same... the condensator also after i check it with V and than put it on ohm it discharge slowli the kill switch is new what can i try?
