Coalinga, CA
My recently rebuilt kx450f blows a lot of white/gray smoke. I removed the spark plug and i see oil on top of the piston.
I do know that timing was set wrong on it and the exhaust valves hit the piston for about 45 seconds.
Also noteworthy when i spun the piston thru the crankshaft i noticed the piston was leaving a lot of oil on the cylinder walls when being moved either up or down. Rings and piston are new. Cylinder is not.
Is it more likely that the valves got bent when the contact happened and bent? therefore they prematurely let oil into combustion chamber?
Or is my cylinder shot out and letting the oil come up thru the rings.
Any help is appreciated guys thanks in advance!
Did you check the cylinder diameters and ring gap or did you slap the top end together without inspecting it?
Similar thing happened to a buddies yzf250, except they put the piston in backwards. Valves hit the piston for a few seconds, they tore it back down and turned the piston around. Bike ran great for 2 entire months of riding every weekend, then it seized right up. The valves had actually broken in half and dropped into the cylinder.
It was a 18 yzf and the reverse engine had confused them. They had no idea the valves bent after the initial run
Post a reply to: Oil on top of piston
