- Pick trends
- Create a private league
- And more!
Just did the Ohlins conversion on my ‘18 KX450 from the SFF-TAC.
Rode once yesterday. Initial impressions are that they are very fluid and confidence-inspiring. Great action and feel.
Only complaint is that they need to be stiffer overall. I’m near the upper limit of oil height and my springs/preload are right on. Same with the shock on feel/stiffness (Flow shock).
That said, I’m heavy (230). More average riders would probably love the valving as-is. I’ll probably get both ends revalved but the potential is obvious. If I can keep the feel and just add some stiffness they will easily be the best suspension I’ve ridden with. The feel on braking bumps was like they weren’t there.
I'm very happy with my revalved WP CC forks on my TC250 so the Dal Soggio would probably be at least as good (similar design).
https://oneclick.com.ee/shop/forks/kyb-cartridge-kit-for-wp-aer-48-fork/
And have Enzo install/revalve.
I can't comment on the Ohlins but can't see how they could possibly be better than the KYB.
You can't beat the HUCK valve, easily the best bottoming control device out there and very good valving to match.
I've had the Dal Soggio Sphere's, Ohlins, A-kit Kyb's (KTM) and Cone forks in the past.
I wasted a LOT of money chasing a good fork for the KTM. IMHO MX Tech is way ahead of everyone else.
AND you can take them out to put into your next fork...
Be sure to post when you get it done.
With the right valving they should all be relatively close. I’ve tried stock and revalved AERs, revalved WP Closed chamber, and CV with cones and traditional midvalves. Craig at Enzo tells me the KYB are better than reworked CVs and after some time on the CVs I would believe it.
So, for full sticker price bang for the buck the MXTech inserts are probably very good. Some used and reworked WP CC would probably be close. There are also a set of KYB inserts in the for sale section now. Might be actual best value atm.
https://www.vitalmx.com/forums/For-Sale-Bazaar,26/Dal-Soggio-Sphere-car…
Some say these are better than KYB, but the internals are very similar to the WP CC. Same seller also has a brand new set of WP CC in for sale section.
Post a reply to: Ohlins TTX carts for AER 48?
