OEM KTM Piston questions
casper
San Diego, CA US
Edited Date/Time 2/4/2019 11:01am
I just bought a new OEM piston for my 2014 KTM 450 sxf and I have some questions about it. I've always bought Weisco replacements so some things seemed a little off to me.
First I wonder if this piston has been returned. The box had a seal on it(it wasn't broken like in this pic), but part of the box was ripped.
When I took the piston out, I noticed a couple of spots where the coating had worn off. You can see round spots on the piston bridge that have worn off. Top middle of the first picture and also last one on the piston skirt.
The piston came with the rings and wrist pin already installed. All Weiscos I installed, I had to install these on the piston myself.
And the last thing, there is this extra wire thing I can't figure out what it is. It doesn't look like its part of the oil ring. It's much larger than the piston so I'm not sure what it's used for.
Is this all normal for a new OEM piston and does anyone know what that extra wire is for? The piston kit came with no instructions either.
dkurtd
TN US
2/1/2019 8:20pm Edited Date/Time 2/1/2019 8:21pm
I'd be sending/taking that thing back. I wouldn't be paying good money for a piston that at best has had a rough shelf life. I can't answer about KTM 450 pistons coming with the rings installed but can say the small bore Vertex Pistons don't come installed. The coating being worn off on the skirt would be reason enough for me to send it back.
Paul_Pitzonka
Grand Terrace, CA US
2/1/2019 10:49pm Edited Date/Time 2/2/2019 12:12am
I’d definitely return that. I’ve never seen a piston come with the rings installed... I believe, the ring with the wire in it is a gapless style oil ring. Although, it’s a little hard to tell from the photo...
PsyCo
FI
2/1/2019 11:57pm
The last picture shows the oil ring that should be behind the ring thats now placed on your piston as an oil ring. At least thats how it is in these new oem cp pistons that also come with pre-installed rings.
Paul_Pitzonka
2/2/2019 12:13am
PsyCo wrote:
The last picture shows the oil ring that should be behind the ring thats now placed on your piston as an oil ring. At least thats...
That’s bizarre... So you have to remove the rings from the piston the check ring gap?
PsyCo
FI
2/2/2019 2:01am
Yep
casper
San Diego, CA US
2/2/2019 12:33pm
Looking at it more, it looks like that big ring is part of the oil ring. It fits but I guess the best way to find out is to check my stock piston when I pull it.
Still not sure about the rings and wrist pin pre-installed. If it's OEM they did a sloppy job with scratching the piston
c0ncEpT
Harrison Twp., MI US
2/3/2019 8:37am
That wire goes behind the oil ring scraper. That's what gives the oil ring it's tension. Without that you'll have a real smokey SOB on your hands.
casper
San Diego, CA US
2/4/2019 11:01am
So then the piston has probably been opened before? I'm thinking with the marks on it and the rings being all weird that someone might have done a dry fit and then returned it?
Post a reply to: OEM KTM Piston questions
