What size is the nut thar holds the front sprocket on a 18 YZ125? Need to take an impact socket home from work & need the size.
On my 2006 YZ125 it's a weird double-stepped nut. I assume all the newer YZ125's are the same?
Anyway, the smaller outer part of the nut is 24mm or 15/16". It seems better to use the outer part as the bigger inner part is very thin, not much for the socket to grab on to.
Powerband in every gear !
I’ve done the job now, it was a 24mm nut, don’t know what this double not you’re talking about is, someone else said the same. The nut was the type with a wider edge on it, like a washer I suppose & the locking tab underneath.
