No spark 1987 cr 250
8/22/2018 4:53 PM
Just put fresh kill switch coil and cdi still no spark????? At wits end!
8/22/2018 5:08 PM
Stator?
If it ain't yer's don't take it, If it ain't the truth dont say it, If it ain't right don't do it...Marcus Aurelius
8/23/2018 4:16 AM
How do I test stator I put volt tester on and when I kick it spikes?? Not enough juice maybe? Has new magneto!!
8/23/2018 4:20 AM
Stator or weak magneto.
Did you make sure the ground is good? Harnesses have zero resistence?
8/23/2018 9:12 AM
frame mounts not rusty?
8/23/2018 5:12 PM
Coil shows 10.76 ohms? That's new coil old coil 17.6ohms
8/24/2018 6:17 AM
Is that the primary side or the secondary side readings?
The higher reading on the primary side is a good thing, but not if that is on the secondary side.
More info needed.
Check you engine mounts for rust. The stator grounds to the engine and the coil grounds to the frame, so these mounts must be rust free for a good connection.
What color is your spark? Blue , Orange or white/ Yellow. Each color tells a story.
