AL
2013 CRF250 won't start unless I run the fuel pump for a few seconds manually (connect to a 12v battery at the plug). Once gas line is primed it fires right up, 1 or 2 kicks, and bike runs great until you shut it down or stall it. Any ideas what's going on here? Bad pump, injector, some other electrical issue ?
When the injector is dirty and does not close complete, it will drip the fuel out.
Fuel pump may also be leaking fuel back into the tank.
Post a reply to: No fuel pressure at startup
