Landenberg, PA
9/16/2020 10:00am
Just picked up a pair of SFS clamps (used) and the travel indicator o-ring is missing. Was wondering if it's easy enough to take one of the air chambers off to put a new one on. It looks like there a lock ring holding it on but don't want to ruin a seal and mess them up.
Do you check the pressure every ride? Being such a small chamber it's really hard to tell if the air is leaking or not. When removing the pumpi as fast as I can, I'll still lose 10 psi. I guess the trick is to overfill them by 10psi? Any tips?
Naturally, when you reconnect the pump it has atmospheric pressure, so the 10psi loss you’re seeing is just to pressurize your pump again. Not your chamber being low by 10psi.
So pump it to what you want and that is the psi in the chamber. When you reconnect it, you’re going to lose some into the pump but it doesn’t matter, just pump it to where you want it and keep riding.
Post a reply to: Neken SFS triple clamps - how to replace o-ring?
