Frederick, MD
1469th
10/18/2019 9:54am
First off, if this is not the appropriate section please let me know and I will remove it.
I took about 10 years off from riding dirt bikes, got the itch to ride again and bought a 2014 YZ250F. The bike has over 100 hours on it (figured that out after I bought it), and its unknown if anything has been rebuilt (I was stupid and bought the bike anyway). I took the bike to get it looked over at my local dealer and everything checked out great. The dealer did a compression test and a leak down test and he said the bike looked great.
My question is, should I sell the bike and get something newer? Should I get the motor rebuilt (Top-End) and just keep the 2014 YZ250F? I will not be doing the work for the rebuild, so I am worried about the cost of a the rebuild vs value of the bike. I have a couple trade offers as well (older 125/250 2-strokes).
I do not intend on racing, I just enjoy riding casually on tracks and some trails locally.
Any advice would be appreciated.
Thanks
Thanks
I have a friend that did an easy 150 on a 2015 or 2026 Yamaha. If the bike is running well and seems to be fine. Ride it for a bit then sell it.
If money isn’t a problem, get rid of it and move on to something newer.
Thanks for the response!
Look at it this way, if you like the bike then make it nice and reliable and ride it for 2-3 years. A newer bike is going to be another $1500-$2000. Youre spending the money either way. Even if its newer, you STILL dont know whats going on in the motor.
Thanks again
There were some select cases of connecting rod failures(not many but worth knowing) I changed my piston at 30 hrs and since I was already in there had my crank rebuilt with a Carillo rod for a piece of mind. When it comes to preventative maintenance I peronally go the extra mile. Otherwise its been a solid bike w lots of power.
There were some select cases of connecting rod failures(not many but worth knowing) I changed my piston at 30 hrs and since I was already in there had my crank rebuilt with a Carillo rod for a piece of mind. When it comes to preventative maintenance I personally go the extra mile. Otherwise its been a solid bike w lots of power.
I will look into the impeller and shift stopper issues (I think I read about them already on here).
Thanks man
Im still fine tuning it but this map really moved the power to mid/top. Smoothed out the abrupt throttle response Off the bottom which was making cornering a real problem early on. Also allowed it to rev further vs falling flat on its face up top.
i also dropped a tooth on the rear and went 5mm up in the clamps. It took me a while to find a good setting. Sag is around 105-108. I had to drop a spring rate as well do to my weight.
Happy to share any other setup tips if needed.
Post a reply to: Need some bike advice 2014 YZ250F
