Gilbert, AZ
I have a 2013 KX450F with the KYB Air Forks. I have no idea what pressure to run. I think stock is 35lbs? I was out riding the other day and on a 10ft drop I bottomed out HARD! It was a flat landing but still... Stinger in the wrists! Is that normal? Obviously I don't want them rock hard either. That just seems like a pretty small drop to be bottoming out on. Do I just need to adjust compression rate? I only weigh 155lbs too so I'm not a huge guy. Any help would be AWESOME!
And please don't just link that video the Vital put up a few years ago. That does not help. It just shows how to put air in the forks. I can do that. I'm not an idiot.
(4) Never-exceed number.
The suggested pressure range on the KX450F is 32 psi to 41 psi. Never pressurize a PSF fork leg to more than 73 psi.
http://motocrossactionmag.com/news/mxas-2013-kawasaki-kx450f-motocross-…
Remember, you have clickers to fiddle with as well. Go all the way clockwise with the ones on the top and then back out 10 clicks as a starting point. Clockwise will make them slower (stiffer) and counterclockwise will make them faster (softer). There are usually 21 adjustment settings on compression clickers.
Post a reply to: Need help with Fork Setup
