Need help with 2007 Rm 250 carb set up
12/19/2017 12:13 AM
What's the best set up for 2007 rm 250 carb jet sizes?needle height ? And anything else would be appreciated
12/19/2017 2:07 AM
I'd go by what Pro Circuit recommends.
https://www.procircuit.com/jettingspecs2.htm
12/19/2017 5:15 PM
Thanks man I'll check it out
12/20/2017 3:30 AM
Some very knowledgeable guys on here when it comes to jetting. Post up more info such as typical temperatures, altitude, fuel/oil ratio, any engine work etc to get a more accurate response.
However from my experience the stock NEDH needle is pretty good. The NECJ that pro circuit is also popular but slightly leaner than the NEDH.
Pilot, anywhere from 45-50 depending on temp and needle choice.
Main usually between 165-178
48 Pilot, Clip3 NEDH and a 170 main would be a safe start
@russ_69
12/21/2017 2:21 PM
RussB wrote:
Some very knowledgeable guys on here when it comes to jetting. Post up more info such as typical temperatures, altitude, ...more
When you say clip3 are you counting from the top or the bottom?
12/21/2017 6:27 PM
12/21/2017 9:55 PM
dirtmike86 wrote: Photo
Thank you! that was helpful.
