How do i figure out what kind of rear shock spring i need? i need a softer spring but dont know what spec and how to find out or what company to buy it off for a decent price. Can anyone give me some sizing guides and suggestions?
Thanks
Thanks
Racetech has a spring rate calculator. Enter your bike, weight, skill level and theyll tell you. This calculator is on their website. I used it for my shock and forks and i like it. I believe the total for springs was $250
What bike? There are some measurements and calculations that can get you dialled better than some of the online sources
Thanks ill check it out! I thought racetech was from USA so shipping to aus would be expensive.
Yea just use it to find what you need and order from an aus company
Get a progressive rear spring. Need your weight, height, and type of riding to get you a correct rate.
Unless your bike has the stock spring and someone has the correct spring rate for it, you will not be able to determine what spring is better/lighter unless you get your measured.
