I need help with my kx 125 that i rebuilt. After i put everything back together it will not shift at all besides down a tiny bit. Anyone have a idea of the issue?
There are a lot of things it could be, but more info needed.
1. Did you split the cases?
2. Transmission removed?
3. If so, did you test it before you put it all back together?
If you did not split the cases...Look at your shift shaft parts to see if you have them back in correctly.
Yes I did split the cases to change the crank but i left the transmission in place. I will check the shift shaft though
