- Pick trends
- Create a private league
- And more!
Do I need to put some grease on the copper gasket? (Permatex Aluminum Anti-Seize?).
I know I should put some on the engine/exhaust port bolts.
Can you show me by photos where to put the anti seize and where the copper silicone?
And the aluminum anti-seize grease will go where the bolts get hot, right?
Just use the oem bolt? (I don't have any washers, etc..) Seems kind of weird.
The manual just says to put a new copper gasket and that's it.
What about the muffler mounting bolt? It doesn't have rubber / washers. I hope it won't vibrate and damage my frame like the KX450.
It comes like this:
And i made it like this:
After purple it can get to blue real fast and even turn bright blue and you can't change it back, happened to me once but I managed to make it blend in. This is my first time doing something like this.
(I'm a professional graphic designer so I guess it helps with the touch lol).
By the way, the head pipe that goes into the engine went all bright blue after 2-3 rides. Kind of a bummer but I knew it will happen from the heat.
Post a reply to: Must replace copper gasket?
