- Pick trends
- Create a private league
- And more!
Some mousse is better then others. Dunlop, Nitro and pirelli works good and holds up 15h or so. Michellin has better feeling and is lighter but does not hold up very well.
Mousse requires that you match the tire with the right mousse. Different brands can be matched.
Mousse tubes are a must if there is any risk of a pinch flat, or tearing the valve (MX or offroad).
The only downside (IMHO) is the cost of buying and replacing them (~1 set per year for a weekend racer) and learning a new technique to installing them.
Depending on tracks and weather (hot/cold) you can get maybe 20-30h out of them,
I do around 100-150h per year on mousses.
If you run Pirelli MX32, 110, you can fit either Dunlop, Pirelli or Nitro mousse in that tire. Nitro you might want to go with a 100 mousse though, or you need a rabakonda or similar to insert the mousse since it is big. Nitro 110 fits better in the bridgestone 110.
Michelin 110 mousse also works in Pirelli and Dunlop 110 tires. Michelin front mousse (M15 or M16) does not fit well in Dunlop MX32 front 21-80/100 tire, thats all i know. But fits good in Pirelli 21-100/80.
I recommend your first mousse to be Dunlop or Pirelli 110, and use a Pirelli or Dunlop MX32 110 tire.
You get used to what you ride, though.
Tubeless systems are extremely unreliable if you are a racer and need to a avoid flats. Both myself and some other riders I know that was sponsored by tubliss got more flats the the ones running tubes.
Avoid flat in rear you need around 1-1.2bar minimum on a tube unless you run perfectly groomed tracks with no rocks or square edge stuff.
And Soon as you get a small dent in rim you are done. Riding with tubliss on a flat is just as bad as - running a flat, speedwise. Feels like crap and bike behaves bad, but tire will stick. That is why it has not taken off. Suits the average Joe that does Max of 4 tire changes per year and with that has a controlled environment that is not subject to a lot of variations.
Post a reply to: Mousse for MX?
