Motoseal on reed gasket?
10/18/2018 11:52 AM
Bought a new reed gasket for my yz250 and was told by some others users of another forum to use a thin coat of “motoseal” on both sides of the gasket when reassembling. Local auto parts store has it but for $10 a tube its kinda pricey for only needing just a tiny bit when thenrest will sit in the tool box forever... is it actually necassary to use it or any type of “sealant” on this gasket?
10/18/2018 12:52 PM
Needs to be sealant that won't be eaten by the fuel and up to a certain temp as it's right off the cylinder. Any rtv should be good I used threebond on mine
10/18/2018 1:20 PM
grimsypro wrote:
Needs to be sealant that won't be eaten by the fuel and up to a certain temp as it's right off the cylinder. Any rtv should be ...more
Would it hurt not to use any? I really dont feel like spending $10 on a giant tube of sealant and using half a fingernails worth. Kinda tight on funds as im doing other things to my bike...
10/18/2018 3:47 PM
On my 2001 yz250, i didnt put anything on the gasket. Had no issues. If you want, you can put belray waterproof grease on it if youre worried about air leak or something. I really dont think a coating is required anyways. Just make sure your surfaces are clean and you tighten it correctly
10/18/2018 3:57 PM
You’re fine putting it on dry. I’ve used yamabond to salvage a torn gasket, but other than that there’s no need
RPM Performance
CT
783
10/18/2018 4:43 PM
Sealing is what gaskets do. As long as your manifold junctions are flat and straight, you don't need any sealant.
Braaapin' aint easy.
10/18/2018 4:46 PM
Thanks for the opinions guys. Currently going through an air leak battle with the bike and working on fixing it so i wasnt sure if just cleaning the surface and using the gasket dry was ok...
10/18/2018 7:51 PM
kb228 wrote:
On my 2001 yz250, i didnt put anything on the gasket. Had no issues. If you want, you can put belray waterproof grease on it ...more
Years ago I'd use sealant on all paper gaskets. I was paranoid about leaks.
Then when I worked at the Maico (and Acerbis , UFO, MSR and other products) distributors, working on my 320, trying different things, that required a fair amount of 'on' and 'offing' of gasket jointed parts, the owner put me onto using grease on gaskets. Not so much for a seal (which it does enhance) , but to avoid sticking and tearing of gaskets and laborious joint clean up .
I certainly don't do it with everything (nor recommend it) , but, for example, with my current experimenting with reed block / carb spacers (one of which is a pick up / exit point for 2 Vacuum lines for an automatic de-comp and a Mikuni fuel pump for my 500s 'drop' Tank) , I use sealant on the one side that will be the semi permanent side, and a light coat of grease on the 'removal' side. Works well and I've never had a problem over several decades.
It also has kept the original, big, thick HM / E Line Lighting kit gasket healthy over 15 years, and, hopefully, now the same type of gasket on the dodgy Electric start kit I use from time to time. The mongrels who made that should have used an Oring, and positive stop, male to female 'engagement' fitting of the sidecover, to the engine cases.
10/18/2018 8:14 PM
Motoseal does work very good on the reed block but any gas-resistant sealant will do. I think Motoseal might actually be Permatex Ultra-Grey just relabled to appeal to the motorcycle crowd,
Powerband in every gear !
10/19/2018 7:56 AM
You install it dry and then leak down test it. If it leaks then you use sealant.
10/19/2018 8:43 AM
I did a leak down test and my bike looses air due to the powervalve seal. Even using a new seal.
10/19/2018 8:54 AM
Did you make sure all your surfaces are flat? If the bike ever overheated you could have warped gasket surfaces that wont seal.
10/21/2018 6:23 AM
I had a very slight leak from my power valve cover. Was barely bubbling up after 10 minutes. Smeared a bit of grease both sides of the gasket and it went away. Is yours on the inside where the rod goes through?
10/21/2018 6:52 AM
grimsypro wrote:
I had a very slight leak from my power valve cover. Was barely bubbling up after 10 minutes. Smeared a bit of grease both ...more
Yeah its a very common issue on yz250s. The bore where the rod rides inside the seal gets warped or whatever and it will never seal right unless you buy a new cylinder or do this mod where you press a metal bushing into the hole. I did pull the gasket off and add a bit of grease a while back as well.
10/21/2018 6:52 AM
kb228 wrote:
Did you make sure all your surfaces are flat? If the bike ever overheated you could have warped gasket surfaces that wont ...more
Read my last reply below. I explained why it wont seal.
10/21/2018 11:44 AM
I did read up in it when mine was leaking. Sounds like a pain in the ass! Did you get it sorted?
10/21/2018 12:35 PM
Not going to worry about it because it causes no issues besides making a stain which simple green and a scruber will get rid of
10/22/2018 2:33 AM
Ye pretty sure it shouldn't cause a leak as the power valve is under positive pressure.
