Monster front brake setup!
7/9/2021 1:20 PM
Edited Date/Time: 7/9/2021 3:59 PM
I had mounted this caliper to my CRF450 some time ago and just loved it. Radial mount, four piston caliper. Way more efficient than a floating caliper. Hung on to the caliper when I sold that bike and finally got around to mounting it to the Showa conventionals I had swapped to my KTM 200. https://www.vitalmx.com/forums/Tech-Help-Race-Shop,42/49mm-Showa-conventionals-conversion,1387998
Mounting the caliper to the Showa conventionals was more complicated then on the CRF. With the CRF all I had to do was whip up a simple bracket and rotor spacer and I was good to go. https://www.vitalmx.com/forums/Tech-Help-Race-Shop,42/Monster-front-brake-set-up,1315296
With the Showa conventionals, despite numerous attempts to fabricate a bracket to bolt to the fork lug, I could just never get the caliper to sit properly. Because of the caliper bracket shape and dimensions, it was always too low or whatever. So eventually I just had to go full ham and modify the lug itself.
This was a little bit out of my comfort zone so I definitely took my time and kept things surgically clean. I machined some lugs to act as receivers for the caliper. Cut the fork lug and then carefully tacked everything into place. I also went with a slightly bigger rotor. Not that the caliper needed any more power, and now it is in complete overkill territory, but so that the caliper is moved a little further away from the center and therefore further away from the spokes. As it is, I had to machine a spacer to move the rotor out from the hub about 6 mm.
The thing is definitely powerful! Definitely a one finger setup. I freaking love this. I think if someone really had their shit together, they would make a smaller 4-piston caliper that would not require spacing out the rotor and then offer it with various brackets to fit the OEM fork lugs. Floating calipers are just so freaking archaic!
7/9/2021 1:22 PM
Edited Date/Time: 7/9/2021 1:37 PM
Spacer to move the rotor out 6mm.
I use Dykem in excess because it just seems so machinist-like. hahahha
But actually, I have just found that the smaller, more precise and tightly I mark things, the
better my results. I know some people can nail .001" with a felt tip marker, but that ain't me.
I'll take all the help I can get.
7/9/2021 1:26 PM
Measure, cut, grind, clean . . .
7/9/2021 1:32 PM
Surgically clean, preheat, welded with Zen like focus, build up, shape, finish.
Very happy with how this came out!!!!
7/9/2021 1:38 PM
AWESOME WORK - thanks for sharing!
Contact me at: VitalMX123@outlook.com
7/9/2021 1:39 PM
Thank you! Much appreciated.
7/9/2021 2:03 PM
Looks factory. What holds the lugs on the lower tubes?
Powerband in every gear !
7/9/2021 2:37 PM
Fucking sweet.
7/9/2021 2:46 PM
Edited Date/Time: 7/9/2021 2:49 PM
Thanks!
These lugs are threaded on like normal but don't have the usual set screw. Just lots of Loctite.
Took a lot of heat to get it off! Used red on the re-install.
7/10/2021 11:14 AM
Awesome job. Very trick.
7/10/2021 12:09 PM
That's some nice fab work, well played man!
7/10/2021 12:46 PM
Richy, Robinson and Munson-
Much thanks!
7/10/2021 1:54 PM
Great share. I love to see this stuff. Nice, clean work!
7/12/2021 7:15 AM
Thank you!
