Mods for 2017 Kx250f
8/29/2017 7:51 PM
Edited Date/Time: 8/29/2017 7:52 PM
what are the best mods to do for the 2017 kx250f? also what are the best exhausts systems and clutches?
cheers
8/30/2017 12:16 AM
Hinson clutches are amazing! Once you ride with one, you won't go back!
8/30/2017 9:13 AM
Suspension first.
THEN....
When i buy parts, i generally go with what pro teams are using. Not because other brands are bad, but because im sure pro circuit has better kx exhausts than fmf does from developmemt time. Obviously its not THAT critical. Going with ride engineering triple clamps over pro circuit isnt going to make or break your bike. Same with pipes and clutches. If you were an advanced rider you would know exactly what you want. Pick some shit from known proven brands that look sick and go. Pro circuit is great, hinson/rekluse/wiseco clutches are all good. Fmf, yosh pipes are good. Cv4 hoses etc. look at some racerx builds.
2009 Kawasaki KX450F
2009 Kawasaki KX250F
2002 Suzuki GSXR 600
8/30/2017 10:40 AM
Stiffer clutch springs ASAP!.......
8/30/2017 4:46 PM
Edited Date/Time: 8/30/2017 5:01 PM
im an A grade junior rider and have an idea of what I want but I wont some other opinions as to what is the best for the kx250f performance etc. I am planning to run a akro full system, hinson clutch and other obvious bits and pieces as that's what I usually run but wanted to know what you all thought. also thinking about a vortex ignition but undecided.
also what do you guys think about rocket exhausts? ive heard good things but don't know where to get them in Aus
8/30/2017 6:51 PM
tm chain slider kit
If I'm healthy enough to complain. I shouldn't be complaining.
8/31/2017 5:11 AM
Edited Date/Time: 8/31/2017 5:13 AM
Can't go wrong with Akra, excellent products.
#1
KX125
8/31/2017 1:11 PM
Ignition, pipe, race fuel, hinson, tm.designs chain guide . Mr12. And suspension for you. Bike will be more than enough. Unless your a top 20 pro card holder.
