Kechi, KS
This is on a 2018 ktm 125. In the course of my pursuit of better jetting specs, I’ve had issues with the plating flaking off of the replacement slides that I have purchased. The original 4.0 had 70 hrs on it with only minor scuffing but no flaking. The Kx125 5.5 slide started flaking right away, and after 10 hrs I pulled it for that reason, and I also felt like it was too lean of a slide. Then I purchased a 5.0, from JD Jetting, and it’s held up better, but l I’ve noticed a bit of flaking on it after about 15 hrs. Also, the inside of the throttle body appears to be smooth. Has anyone else had these issues?
Transforms the bike
Post a reply to: Mikuni tmx 38mm throttle slide plating issue
