SE
8/10/2022 9:42am
Hello . Was about to do an oil change and found this in the filter ! Huge amount of metal in the filter , looks like aluminium)
Bike has done about 60h ( not used for 4years)
Crf 450 2013
Where do i start looking for problem?
/Mattias
Crf 450 2013
/Mattias
Looks like most metal comes from the center of the case . Pulled the left side cover , nothing unusial there .
Its both aluminium and Steel (magnetic)
Guess my next option is to split the engine !
Engine was running fine before and i herd no knocking or scraping sound
Sorry for my poor english
This is what fell out the filter when i dropt it..
What i found was that the crank has shaved of aluminium of the left and right engine case .....
Looks like i can reuse the cases but what you think about the crank?
Its blue arund the bering surfaces !
Shoud i change the whole crank or just new berings?
Here is some (bad) pictures of it
Total on hours on the engine is 60 ..
/Mattias
Since its all split anyway, its time for new OEM crank, bearings and gaskets.
I'd look closely at the clutch and transmission too.
Oem crank is (in dollars) 491 plus bearings and gasket
Hotrods is 530 including all you need .
How bad are the hotrods?
Yes i Will clean and inspect transmission to
Cluch is fine basket is good to
/Mattias
Also. Is that a 24mx/twenty oil filter? The colour sure looks like that.
NEVER use those... 8/10 I removed in customers bikes when I had a shop were showing signs of vacuum/ sucked inwards (cant describe in English. Dom hade sugit ihop sig i filterytan)
Last time i used the bike was 2014-15
:p
My plan was to start it and change oil .
Gues it dident like to be forgotten
I think i Will get new Main bearings an hope it makes it to 100h then change crank . IF not ..... Well i always missed my cr250 so how about a af build ?
Obviously, replace the top end.
Definitely do all the bearings/seals in the cases since it's apart and they may have metal in them now.
Clean the transmission and clutch REALLY good. Lots of places to hide metal shavings.
Check the clutch plates wear levels. You may just want to replace the clutch as well. Might save you time in a few hours if it's worn.
Saw a little of aluminium chip in the oilfilter and have recently split the crank.
How did you solve the problem? How long have you been ridden it and was there no sign for a new bottom end rebuild?
In my case the engine (crf450 2012) have 83h and everything inside is oem. The crank, bearings, sealings etc was new when it was rebuilt!
Can upload some photos about my problem..
Post a reply to: Metal in oil filter crf
