Reidsville, NC
11/25/2018 12:36pm
I've been having front brake issues that past few rides. I have a 2018 husky fc350. I bled the front brake about a month ago, and everything worked great. Yesterday it faded again, so I bled it at the track. It worked for about two laps, then the brake was gone again.
Do I have leak in the master cylinder? Wonder if anyone else has had this problem with magura.
-worn pads
-bent rotor
-low heat index with the brake fluid
-improper bleed
-ruptured line
-bad seal
Because you bled it already (and confident you did a a good job), start with new pads, check the rotor for any bends and inspect the pistons to make sure they are not sticking. I would also check which fluid you're using to make sure it's not old and has absorbed moisture. I would also do a visual of the brake line too...
Although if you say after being bled it is good for a while it sound like air is getting in from a damaged / loose hose, although if this was the case you would probably see some oil seepage.?
So the stock part is the brown plunger, the new is the aluminum one. Confirmed the part number and description. To further confuse things, I bought this bike brand new, yet it has a brembo front brake. I thought husky came with magura?
I also thought that the magura and brembo internal parts were interchangable?
Post a reply to: Magura brake fade
