MXA article on '23 KTM/Husky linkage bearings
JK714
Durham, NC US
Edited Date/Time 10/2/2022 6:54pm
The October issue of MXA has an article on p.128 about problems with some of the new '23 KTM and Husky linkage needle bearings "walking out" and ultimately hindering suspension movement. They say it happened on half of their test bikes, including the FE models.
Has anyone experienced this?
MXA recommends replacing with caged bearings (HK2216, P/N 58033097000) if this happens.
JK714
Durham, NC US
9/8/2022 6:52am
not online yet, here's the print copy
fcr
Monkeys Eyebrow YE
9/10/2022 6:41pm
Thanks
JoeB10p
Washington, PA US
9/11/2022 6:46pm
When I look at the parts fiche that part number is the same as what's already on my 23 so I'm not sure what's supposed to be the deal.
JK714
Durham, NC US
9/12/2022 6:51am
I believe what they are talking about is replacing the stock linkage knuckle uncaged needle bearings (HK221 2V) with the same caged needle bearings used on the pull rod (HK 2216). Can't tell from the fiche parts description, but the inner and outer dimensions of the two bearing types must be the same for that to work.
Honestly I don't know why the manufacturers don't just go to caged bearings everywhere. The loose needles are such a PITA.
sandman768
Saratoga Springs, NY US
9/12/2022 7:04am
JK714 wrote:
I believe what they are talking about is replacing the stock linkage knuckle uncaged needle bearings (HK221 2V) with the same caged needle bearings used on...
The loose needles in the swingarm & linkage are definitely a PiTA….But I think they hold more grease than the caged needles…
Luxon MX
San Diego, CA US
1205th
9/12/2022 9:22am
Loose needles have more load capacity than caged bearings, which is generally why they're used here. But, if the loose needle bearings are walking out, there's no reason why caged needle bearings wouldn't also walk out.
It sounds like the knuckles were bored too big, which allows the bearings to walk. Only a properly machined knuckle or Loctite sleeve retainer (6XX series) will stop that.
11
JK714
Durham, NC US
9/13/2022 8:13am
Thanks for that insight Billy. MXA also recommended using the Loctite 648 to secure any replacement bearing. I'm guessing that at my level (Vet C class) the caged vs uncaged load capacity is not so critical, and the caged ones sure are easier to deal with.
cruiser450
Chilliwack, BC CA
10/2/2022 6:51pm
7hrs on my 23 250sxf decided to pull apart to grease it, found both seals sideways and water in one side bearing because of it, i also noticed the lower shock bolt just touching the linkarm.not ridden in mud or rain, all dry tracks. All the bearings are ok no movement but im replacing the bearings in the linkarm anyway because the water.
DB97
Orlando, FL US
10/4/2022 3:36am
cruiser450 wrote:
7hrs on my 23 250sxf decided to pull apart to grease it, found both seals sideways and water in one side bearing because of it, i...
That’s how my 22.5 was. Both of those seals were pushed out.
Post a reply to: MXA article on '23 KTM/Husky linkage bearings
