Lowering pegs for yamaha
2/6/2019 6:45 AM
What pegs do you guys suggest that is lower then original and fits for the yamaha 250f 2019?
im about 6´1 and i think it would help some to get them lower.
2/6/2019 3:01 PM
I run the Fastway pegs by ProMoto. These pegs are adjustable and you can either run them in the standard position or the down and back.
2/6/2019 4:14 PM
Not completely sure on the newer models but on the 2010-2012 or so, the 450 pegs were about 5 or 10mm lower than the 250F pegs. Bolted right up and much cheaper than aftermarket pegs.
Powerband in every gear !
2/11/2019 10:26 AM
hmm cant find any fastway pegs by promoto for the 2019 yamaha, found some for KTM.
Might be the same between the yamaha models, just that they have not updated their website?
2/11/2019 2:53 PM
May be worth giving this company a call to see if the 2T and 4T peg mounts are identical...12mm lower is about all you'll get out of any option. Also, have you thought of going to a tall seat foam? Then you won't deal with your heels potentially hitting the ground/snagging ruts with the benefit of more leg room...
https://www.systemtechracing.com/product_p/55-04.htm
