Le Roy, NY
2001 Honda cr125r. Gurgles and bogs when you stab throttle than takes off..
Fmf sst pipe, Fmf power core 2 shorty silencer ,Boyeseen reeds,Twin air airfilter. Paid local honda shop to rejet came back with 420 main jet nothing else changed ( 380 stock )... Any help is appreciated before it gets hung on the wall as art..
Slow jet #45 (stock)
Jet needle 6BEG20-68 (stock)
Needle clip position 3rd groove (stock)
Main jet 420 (380 stock)
Stock float level
New York state not sure about elevation
Run 93 octane pump gas with 927 mixed 32:1
Plug looks clean like new..
https://thumpertalk.com/forums/topic/1284669-mikuni-jet-block-gasket-fa…
Bog problems when you "stab" the throttle are almost always pilot jet and air screw related.
To adjust your air screw properly, adjust your idle so the bike won't stall and start with the air screw at 1.5 turns out from all the way in. Turn the air screw inward until the idle misses, then turn it outward until the idle misses. Your sweet spot is exactly halfway between these two spots.
If the idle won't miss as you turn the screw all the way closed, your pilot is too lean. If it will not miss as you turn it out, the pilot is too rich.
Post a reply to: Losing mind jetting...
