Marietta, GA
Ive got some ODI's on a 20 yz125, I noticed the thickess of the cam surface that the cable rests on is significantly more narrow than stock throttle tubes surface. It hasn't gotten stuck just operating it on the stand but Id rather find lock on grips with a throttle tube exact same width as stock ...anyone else notice this?
When the throttle is closed, there isn't room for the cable to slip off the side of the quadrant.
When the throttle is wide open, you can push it off either side with your finger.
Try it while holding the pulley in place and let the throttle close to see what happens.
Mine pops right back on due to the angle the cable enters the quadrant and the tension.
If it's a serious concern, you could make a large thin shim to take up the extra space between the quadrant and the housing. If you do that, make for damn sure your shim is smooth and cannot bind up the throttle.
Post a reply to: Lock on grip throttle tube compared to stock
