NC
My buddy just installed a Lectron on a 2015 YZ125, and the air boot is now pressed up against the shock spring. He called Lectron and they said perhaps remove the reed cage spacer. Anyone have any input or experience on this matter?? Pros/Cons of removing a reed cage spacer??
This is why I avoid aftermarket carbs which tend to have poor fitment compatibility.
The Lectron does not fit w/ the reed spacer (at least for us). The Lectron does fit without the spacer but does rub the air boot just a lil. The air boot also rubs on the shock due to the reed spacer (3/8") on the mod motors. The air boot rubbing is not an issue and never has been.
The Lectron on our YZs has been really good.
One thing to consider is that I used this 2 years ago and I think they’ve had a lot of development since then. The setting I had was smooth and easy to ride for trails which makes sense because that’s mostly who used those carbs at the time.
I went to the stock carb with JD jet kit and the bike is super crisp all over.
Post a reply to: Lectron fitment issue; air boot against the shock - YZ125
