11/9/2022 9:29pm
Hay guys,
Brought a set of kxf suspension of 2014 250, mainly for the forks and triples.
Searched and found conflicting info so im hoping someone can tell me if they used a kxf shock in there 125. Mines a 2003 too btw.
I also have a set of pc kx250 dog bones which are 2mm longer than stock wether that helps it work better?
Step 2 would be in step 1 fails, add internal spacers.
If you scroll towards the bottom, Coal gave out some very good info on this.
I want to start collecting parts for a 2004+ kx125 so I’m kind of in the same boat.
But definitely start with Enzo. Great guys that love to share their knowledge.
https://m.vitalmx.com/forums/For-Sale-Bazaar,26/For-Sale-KYB-Factory-2-…
Good luck with everything 🤘
So, correct me if I’m wrong but won’t you be losing travel causing the bike to sit farther into the stroke?
https://m.vitalmx.com/forums/Tech-Help-Race-Shop,42/KX250F-shock-on-an-…
Why I suggested contacting Enzo or Technical Touch for a shorter clevis. Just don’t know what clevis would work on a kx125 and fit an 18mm shaft.
Nice 125!
I
Post a reply to: Kxf shock in kx125
