Kx250f engine hesitating
8/2/2017 2:11 AM
Engine idles good but when given about 1/8 throttle the engine hesitates like if it was bouncing off the rev limiter.And the carb has a small o ring that is crushed so I was thinking it might be an air leak.The vale’s are adjusted correctly and the timing is 100% set.
8/2/2017 4:25 AM
If that bad o ring is on the fuel screw it will make it run strange. Replace that o ring.
The fuel screw has a great effect on the entire engine rpm range and has to be adjusted correctly.
8/2/2017 7:46 AM
The fuel screw has no spring or o ring ??
8/2/2017 9:45 AM
It should have the screw, spring, flat washer and then the o ring. Other wise it will not work.
8/2/2017 11:06 AM
The engine runs but doesn’t have no power when given throttle the fuel screw has no spring or washer or o ring
8/2/2017 12:01 PM
Thats your problem...
8/2/2017 4:03 PM
X2...like PawPaw said...it's leaking air and running too lean.
Many thanks to everyone helping me out this GNCC season: SRT Offroad, Acerbis, FCR Suspension, O'Neal Racing, Evans Waterless Coolants, Rekluse, Twin Air, Braking Brakes, Carbsport
Profile image credit Ken Hill Photography
