I know I saw an ad for Ktm oversize footpeg pins but now can't find
stock are 10mm o.d.
A UK company AS3 has them ( 11mm )
Anyone ? ….thanks
stock are 10mm o.d.
Anyone ? ….thanks
Edited Date/Time:
slavens carries them... XC Gear
edit- I will add that Terry Cable used to and may still have foot peg rebuild kits which are slightly oversized pins with a drill bit, they work great. Can't imagine forcing these oversize pins thru without a consdirable amount of wear.
Yes , i want to drill thru the pegs/brackets to accomodate the 1mm larger pins to tighten up the fit
edit- I will add that Terry Cable used to and may still have foot peg rebuild kits which are slightly oversized pins with a drill bit, they work great. Can't imagine forcing these oversize pins thru without a consdirable amount of wear.2stmark wrote:
best way to do it, works great and makes the bike feel tight again.
