So I crashed hard last weekend, got up and my front brake was locked. Upon inspection I found the dust cover was wrapped up in the lever causing the lock up. After that though on the way back to the truck it would work at full power if you pumped it a few times.
Got home and figured it had air in the line. Bleed it and bleed it and never got anything but half power at best. I put new copper washers on, replaced the master cylinder plunger and seals with an old set I had. Still half power. I took apart the caliper and checked everything. Still half power.
When I pull the lever all the way into the grip the brake works. The wheel is locked but no way is the system working correctly. I am at a loss. I order new seals, and a new line thinking there might be an issue there? I would love to hear some input and your thoughts. Thank you......
