Grand Rapids, MI
I ordered these aer 48 forks online off ebay. I was told they were off of a 2016 250sxf factory edition, but the part number on the bottom of the forks has me thinking otherwise... Just wanna know what they are off of, and I cant find the part number anywhere on the internet. They were brand new when I got them.
The Numbers are:
34548Q01R-02
1223183-0251
28.06.18 <-- has me thinking this is the date
Any info would be appreciated.
The Numbers are:
34548Q01R-02
1223183-0251
Anyways, I'm also curious to know what model of bike they came off of. I do know that the guys on ThumperTalk say these forks need 10-15 hours to break in. I'll report back when I have mine bolted up to my FE350. I like to ride moto and the XPLOR forks are soft crap on the MX track.
Edited to add my AER forks felt a lot more plush after I switched from the Nekken bar to the Husky Protaper Evo bar with the softest Emig clamp on grips. I don't know what it is with that Nekken bar. It has the same thickness of aluminum as the Protaper at the ends but it made my hands go numb 5 miles into a ride. Protaper is still ok after 15 miles.
For anyone looking to make the same swap with an FE or EXC, here is the article I followed. You should note to slide the forks up to 20mm, you need the optional tall 42mm bar clamps from KTM/Husky.
https://transmoto.com.au/rider-feedback-air-vs-coil-sprung-forks/
These forks are from a 18/19 Alta Redshift MXR.
https://altaownersforum.com/threads/wp-aer-48-forks.2080/#post-27408
Makes sense considering Alta went out of business around the time and a bunch of wholesale forks probably got dumped onto the market. If that link ever goes dead, the AER forks with part numbers 34548Q01L & 34548Q01R on the inside leg are the MXR forks, as confirmed by @vinsanity over there. Here is the kreft review of the suspension on those bikes, if you are curious about the stock MXR situation:
https://www.kreftmoto.com/alta-mxr-detailed-article
I'll probably be shipping out my AER and stock shock for a little bit of their magic soon!
"The fork generates at least double the compression damping force we normally see"
That would explain your harshness. I'm a fan of firm suspension and tend to like jumps and tracks, so I'm biased. I'm going to send these off to Kreft and see what they can do with them.
Post a reply to: Ktm fork part number??
