Ktm SXF 250 2017 Backfires
elikoz
Hillside, NJ US
8/5/2017 11:19am
Hello guys i need your help please
i Purchased the ktm sxf 250 2017 it has 15 hours and its brand new
when i bought it and give a little of gas and go to high RPM when i stop the gas i hearing some backfires
the bike is not getting stopped or something neither when i pull the gas i dont get any back fires
just when i leave the gas at high rpm im hearing and getting some
im jsut wondering why its happens? i see other bikes like me new and they dont have it
much ty
Benton, LA US
8/5/2017 1:47pm Edited Date/Time 8/5/2017 1:48pm
When you close the throttle, you are creating a very lean condition causing the backfire. The TPS may not be set correctly. The TPS will call for a much leaner condition when the throttle is closed very quickly as apposed to just rolling the throttle back. The TPS controls the fuel mixture in every rpm range and is the leanest at closed throttle.
elikoz
Hillside, NJ US
8/6/2017 2:02am
Is it effect the bike some how or losing power band some hiw? Or just ignore it? And why the tps is not correct i just got it brand new lol
How can i fix it
Much ty
8/6/2017 3:47am
You gotta get your sag set correctly. That will stop the backfiring.
Much welcome
HenryA
Stockholm SE
8/6/2017 4:16am
elikoz wrote:
Is it effect the bike some how or losing power band some hiw? Or just ignore it? And why the tps is not correct i just...
How can i fix it
Much ty
Call your dealer then if it's brand new.
Benton, LA US
8/6/2017 7:27am
The dealer may be able to help.
One question first....
Has the exhaust pipe been off the bike? If so, the seal to the head from the pipe will need to be replaced. If it leaks the exhaust will become very lean and also cause this backfiring.
The dealer should be able to check the TPS as well.
elikoz
Hillside, NJ US
8/6/2017 7:40am
Paw Paw wrote:
The dealer may be able to help. One question first.... Has the exhaust pipe been off the bike? If so, the seal to the head from...
it is effect the bike somehow? or i can jsut leave it like this?
and much ty for the seriously responds sir
CarlinoJoeVideo
Portland/Los Angeles, CA US
8/6/2017 8:53am
You can leave it. But if you want to get the best performance you can have it adjusted and fixed.
elikoz
Hillside, NJ US
8/6/2017 10:16am
yea bike has a stock pipe
Bruce372
8/6/2017 10:52am
If it's like the 450, just turn up the idle slightly and try that.
The tps setting on the new bikes are slightly different than the old ones.
8/6/2017 10:59am
That's the one Where you gotta stick a potato in the muffler. It stops the back firing instantly.
Much ty
slipdog
Nor Cal, CA US
8/6/2017 4:03pm
Much ty
He's not going to fall for your old potato in the tailpipe trick!
I-ty okuningi
elikoz
Hillside, NJ US
8/9/2017 7:38am
does anyone haver an idea?
8/9/2017 11:11am
Tamir, you should ask this question in the moto section. You'll get a lot more responses.
Much ty
elikoz
Hillside, NJ US
8/14/2017 8:45am
any seriously thoughts?
Post a reply to: Ktm SXF 250 2017 Backfires
