Ktm Oem head stay : Steel vs. Alum
2stmark
Waterford, MI US
I am a Senior Expert Offroad racer & sometimes MX
Have a 16' 150sx ...comes with Steel head stays
later models are Aluminum & are fairly priced
Would I feel a difference ?
I am pretty sensitive ...lol
thanks
CarlinoJoeVideo
Portland/Los Angeles, CA US
2339th
2/21/2020 7:51pm
I tried the aluminum on my 2016 125 and I liked the steel more because I typically ride rougher tracks.
Aluminum might be better on soft sandy tracks or if you’re looking for more front end traction. Just a give and take.
2stmark
Waterford, MI US
2/22/2020 5:13am
I tried the aluminum on my 2016 125 and I liked the steel more because I typically ride rougher tracks. Aluminum might be better on soft...
Thanks for the quick answer
So... I ride mostly deep sand ( Michigan )
but also would like better front compliance on roots , logs crossings , trail junk that tends
to make your front end lose traction when turning
think Alum be better there ?
Is the Aluminum stiffer ?
CarlinoJoeVideo
2339th
2/22/2020 6:11am
2stmark wrote:
Thanks for the quick answer So... I ride mostly deep sand ( Michigan ) but also would like better front compliance on roots , logs crossings...
Aluminum is stiffer so it could help in soft conditions but on small bumps, rocks and roots it will feel more harsh.
The only way of knowing is to try them back to back.
Bruce372
2/22/2020 11:47am
If they are inexpensive, why not buy them and give them a try.
Even better, have a friend come with you and randomly change them out and cover with duct tape so you dont know which ones you are running... this way, your brain might not trick you
DynoDan22
Victorville, CA US
2/23/2020 8:16am
Yep! Blind test them and report back! Haha
2stmark
Waterford, MI US
2/23/2020 3:54pm
thanks for the thoughts
things you think about during a Michigan winter
Post a reply to: Ktm Oem head stay : Steel vs. Alum
