Edited Date/Time:
KTM 450 EXC-F 2015
I got two 2mm by 2mm neodymium magnets in my clutch side, crank shaft hole, now gone to back of the crank shaft hole and won't go back any further. I won't go into how they got there, long story.
is this clutch side crank shaft hole a oil feed through to crank. And is there a hole the other side of the crank, so I can push bendy wire through and push magnets out from the back of the shaft, because I've got the head and cylinder off as Well. Plus when I tried to blow and suck hard through the crank shaft hole, no air went in or came through, air tight. So im thinking is the clutch side crank shaft hole either not a oil feed, or have the magnets blocked the oil feed??????. Any info much appreciated.
PS
I've tried getting them out with other magnets but no luck.
Do you think because they are as far back as they can go in crank shaft hole, I can drill 1mm diameter, long drill bit and pull it out. Or like I said is there accsess hole behind the crank, so I can push copper wire through and push them out that way.
If the crank shaft hole isn't a oil feed they ain't going anywhere so could leave them in. But if is oil feed they got to come out.
Again any info appreciated
Thanks
Top cat 261076
