Cambs
6/15/2019 10:13pm
Hi, pretty new the mx scene, always had motorbikes as a kid but never done anything serious. Always had 2 strokes but I was lucky enough for my other half to buy me a new Ktm 250 SXF knowing I wanted to start doing motocross, I had a flick through the manual but without reading it religiously couldn’t find anything and was just curious on what I need to keep on top of and the basics of maintaining the bike such as when to change oil, filters, chains, transmission oil, engine oil etc, if anyone can give me some tips I’d appreciate it, thanks!
Air filter - every ride
Chain/sprockets - clean/lube every ride/replace when worn
This bike has 1 oil system, not split. I do oil after 5-6 hour depending on temps and what I’m riding. Oil filter every other oil change. 1000cc oil change and 1200cc when changing oil filter.
Keep the triple clamps bearings greased, linkage and swingarm pivot greased every 20-25 hours.
For oil, I measure it out with a cup based on the manual. Double check it hasn't changed. I do it this way so you are always constant and adding the correct amount.
When you change only the oil, add 1000cc
When you change the oil and oil filter, add 1200cc
Keep the air filter clean. Oiled well. I buy the maxima pre oiled one use filters so when its dirty you trash it and use a new one. $10 a filter. And when you wash the bike cover the side plate hole because water goes straight to the filter if you dont.
Sprockets last a decent while but the stock chain is garbage in my eyes. Replace it with a narrow oring/xring after about 30hrs.
Post a reply to: Ktm 250 SXF Maintenance
