Hey guys, my bike has been stored in the garage for 2 years ? I took it out a couple of weeks ago to get it ready for this season. I changed the spark plus, charged the battery, checked the air filter and took the carb out for a good cleaning. The bike is a 2013 and I am the second owner. I have never had the carb off of it until today and was shocked to find a thick layer of green algae in the float bowl. I sprayed it out really well numerous times with carb cleaner and cleans what I would consider to be 95% of what was on it, off. I worked at it for close to two hours today to get it as clean as I did. I've never seen a carburetor look like that before.
Anyway, when I put it all back together and attempted to start the bike I did start but then I had to shut it off right away because I realized I had the throttle set wrong. Once I got that sorted out it wouldn't start again. does anyone have any ideas or suggestions of what this could be?
I should add that I also drained the gas tank and put fresh gas in it.
Doing any less will just not get the job done.
Thanks!
Thumpertalk has a few threads on carb and how to get it to start/idle/warm up easier.. They take a long time to warm up too because of the lean condition.
The passage the pilot jet screws into could still have some gunk. Fine wire, brake cleaner and air compressor are your friends.
Post a reply to: Klx 140 won't start
