Hey guys, I have a 2018 klx110 that will not run without the battery. A couple months after buying it, it wouldn't start via electric start but I could still ride it. Then eventually it got to the point where it would idle, but it would die as soon as you take off. I used a battery tender to charge it but it kept dying. I bought a new battery and it worked perfect but low and behold, its completely dead again. Any help would be appreciated.
Check all your electrical connections. ( Check the battery voltage with the engine running to be sure it is charging. It should show at least 13.5 volts.) Clean them and then use di electric grease on the connections. Also check all grounds to be sure they are not rusted or dirty or loose.
Post a reply to: Klx 110 Battery
