Green Bay, WI
The kickstart shaft seal on my '16 KX450F keeps popping out every time I take it out on the track. I've replaced it at least 4 times and same thing every time. I installed it using a deep impact socket the same dismeter as the seal. I've tried seating it all the way in and just short of bottoming it out as well. Even tried some loctite 518 around the outside of the seal once. My case breather hose is not obstructed. I'm baffled. Don't know what else to try. It didn't pop out during my last moto today for the first time since I've been having this issue, but I was taking it easy as I was spent and my hands destroyed. Has anyone ever had this issue or have any suggestions on how to remedy it?
I used one of these kits we had at work to look at a 49mm a kit fork tube that was leaking from the lug once I removed the lug to realize there was a crack in it. I think i have a seal kicking around now that I think about it from my 2016 that started weeping on the kick start shaft at 40 or 50 hours that I never installed before trading it in. If i find it, you can have it just cover shipping.
Post a reply to: Kickstarter shaft seal popping out
