Kickstarter Seal Removal
4/17/2018 7:41 PM
2017 KX450F and the kickstarter seal has had a very slow leak for a long time. Decided to finally replace the seal, have tried using a pick and using a screw into the seal to have something to pull on and it will not budge at all. Any other techniques?
4/18/2018 7:27 AM
You may have to pull the cover to replace it correctly.
4/18/2018 7:38 AM
what i did on mine was took a really small flathead and tapped it between the outside of the seal and the case and pried it out. Its a pretty tight fitting seal.
