Kawasaki KX 250 2 stroke 2007 rebuild
10/12/2019 2:32 PM
Hello everyone,
I am currently rebuilding from the ground up a KX 250 07 model. The question I want to ask is I am trying to find aftermarket triple clamps for my bike can I use four stroke triple clamps as they have more types available than my model. Any help would be much appreciated.
Thanks Luke
You ain't living if your not Premixing!!!!!!!!
10/13/2019 7:24 AM
Try ' Luxon MX ' , a poster / member here on this site.
A maker of Triple Clamps, and much more. An impressive individual, and a poster that brings much to this site.
10/13/2019 8:07 PM
Most newer KX triple clamps will work, I'm running a set of 2012 KX250F clamps on my 2005. The only thing you will need to do is modify the stop, www.trickeng.com has a bolt on stop.
2018 KX450F
2005 KX250
2003 KDX 220
1984 KX 80
1982 RM 80
1980 RM 80
1977 XR 75
1969 Honda Mini 50
10/14/2019 11:35 AM
Thanks dkurtd that’s what I was looking for
10/15/2019 12:53 AM
So did you use a 450 triple clamp or 250??? Thanks for your help
3/16/2020 7:08 AM
I'm curious what had to be done to make this work. 2012 250F run 47MM forks and the older 2005 KX has 48MM forks.
3/16/2020 7:34 AM
I had a similar issues a while back. I was lucky enough to find a nice set of used PC clamps through a Vital member and I also ordered a new set through ProCircuit. I know BUDs Racing and Applied Racing still produce new clamps for about $450 and I've heard rumors that ProCircuit will be doing another run of 03-07 KX clamps. You'll have to call ProCircuit and verify if they are.
If your serious about buying a set of clamps make a post on the Sale/Bazaar.
3/16/2020 8:09 AM
If you use the newer forks and clamps you just need the trick steering stop. If you use newer forks in stock of clamps you need a shim for the top clamp.
3/28/2020 1:09 AM
Yes I got a Ride engineering triple clamp and I had to modify the top part of the triple clamp not much and it fits
3/28/2020 1:10 AM
I got a ride engineering set all good mate thanks
3/28/2020 11:46 AM
I’m curious myself as I’ve got a 2006 kx250 what year clamps did you get and what did you have to do to your top triple clamp to modify it, thanks
3/28/2020 4:38 PM
I got a 2017 triple clamp I am in Australia and a guy was selling one on Facebook. So I bought it and contacted Ride engineering And this was there response Photo
3/31/2020 1:56 PM
Okay thanks for your info this helps me a lot 👍
