Pampa, TX
EE
4/27/2021 7:33pm
Soo I have 2016 kx250f with a 2015 sxf250 rod, PC cams(Kawi), springs and other small non-timing-related engine mods, such as KTM main bearings etc. The KTM rod is 3.2mm longer than Kawis original, which required 2 extra links added to the cam chain and a cylinder spacer. The best I´ve got it to run was with the IN cam advanced 2 teeth and EX in stock position, but still bogged down on low revs, ripped hard at higher tho. The spark plug is pretty white. I´ve tried all the possible cam positions without the valves hitting the piston, advancing the IN cam 3 teeth seems too close for me to attempt starting it. Advancing the EX cam only made the bogging worse.
Does anyone with more experience have any insight into what I should try next? Maybe press off the IN cam sprocket and have it put back at a few degrees difference? Maybe mess with the ecu tuning?
Thank you!
Thank you!
Better yet, why did you do that?
If nothing else, a long rod is great for a mx forum username lol
Rods are a easy change with way more upside then downside.
Post a reply to: KXF with SXF internals timing question
