KX500 rear wheel mod
Edited Date/Time 4/5/2018 2:16pm
Bought a 2003 KX500. Doing a 2016 KX450 front end on it. Been reading that if I want to use a new KX450 rear wheel assembly, I will have to modify the swing arm to accommodate for the larger rear axel. Want to avoid this and use as many stock parts as I can. Also don't want to have to do anything funny with the rear brake.
Question: will a kx450 rear rim be able to mount to a kx500 hub? I have an extra black rear hoop, seeing if I can avoid going to buy one!
BobPA
PA US
11/14/2017 9:33am
The rim and hub will work just fine. You may have to buy a set of spokes as I believe the 500's used an 18" rear rim?
sandman768
Saratoga Springs, NY US
11/14/2017 1:36pm
Let me know if you want to sell your 2003 front end....
11/14/2017 1:56pm
BobPA wrote:
The rim and hub will work just fine. You may have to buy a set of spokes as I believe the 500's used an 18" rear...
Thank you for the info, ill give er a try!
11/14/2017 1:57pm
Will do. Going to be a little while as I am still gathering parts before I build.
sandman768
11/14/2017 2:09pm
Great, I"m in the same mode with a 90 K5, just doing some research & deciding what direction to go with it. I know the stock 41 mm forks are not staying on....I can work with 46 mm forks...I believe you will need everything from the kxf to make it work, forks, wheel & brake assy correct?
BobPA
PA US
11/14/2017 4:36pm
Not to hijack this guys thread, but I have a compete front end from a KX 125 I could sell you. Perfect shape. Forks, triples, front wheel, axles, spacers you name it.
11/15/2017 6:28am
sandman768 wrote:
Great, I"m in the same mode with a 90 K5, just doing some research & deciding what direction to go with it. I know the stock...
I bought a set of 2016 kx450f forks and according to my research, they should slide right into the stock triple clamps. Doing this though, I will need the front wheel off a kx250/450f as well as a front brake assy. Should be able to acquire all of these partspretty easy on ebay.
c0ncEpT
Harrison Twp., MI US
11/16/2017 1:40pm
I bought a set of 2016 kx450f forks and according to my research, they should slide right into the stock triple clamps. Doing this though, I...
The forks will fit.
Zerofear66
Anaheim, CA US
4/5/2018 2:16pm
I slid a set of YZ250F forks of a 2015 into my 03 KX500.
Post a reply to: KX500 rear wheel mod
