tb14 wrote:
Anyone have suggestions firstly on chains. O / X ring is what I was leaning towards but open to suggestions. I want as little stretch and adjustment as possible.
Then sprockets if I’m putting the money on a good chain anyone able to suggest some sprockets that hold up very well. Don’t really care about the tiny bit of weight between brands and materials just want what won’t wear out.
Thanks
With the KX 450F there are some initial must have mods. I will answer your question first. Chain and sprockets. I run Sunstar MXR1 Works chains. Amazing on the performance end, but equally on the durability side. Basic clean and lube, and this chain lasts for hours. Sprockets, I use the Works sprocket, 50 T, same amazing results as the chain. They also have the OEM steel sprocket that is stock on the bike.
The must do mods. Chain guide/slider. This has always been an initial Kawasaki mod. I run the Acerbis guide and sliders. Again for the performance and durability of the product. If you have a 19 or newer, you will want to replace your lower roller with a 16-18 OEM, 2 bearing system. Not a must do, but since you are replacing your chain, I run a 116 link chain for better traction and rear suspension feel.
David
774 CC Powersports Kawasaki
Factory Backing Factory Seat
Acerbis Dunlop
Sunstar Braking
MX Engine Stands
Matrix Concepts
