- Pick trends
- Create a private league
- And more!
It looks like you installed the forks on an older 2 stroke. I would intentionally buy a 2018 and older caliper, as it will be better paired to the master from that bike. The 2019 master is different, and I suspect the plunger diameter has changed (along with the whole linkage mechanism to the lever). I love the 19 brake setup so much on my 19kx that I installed a 19 master cylinder on my yz250 2 stroke.
Anyways, it really depends on what size disc you want to run. To make life easy, buy a 2018 caliper, and the 2018 carrier if its not already included with whatever used caliper you're buying. You'll need a 270 rotor for this setup. I'm assuming your running a 2019 front wheel (or at least the 2019 hub)? The 19 axle diameter is larger, so you will need a 19 kx450 hub specifically or a complete wheel if you dont want to lace a wheel. You could run a smaller ID wheel bearing to use an old axle but it wont fit the fork lugs properly obviously.
If you really are that concerned I can grab an old 250mm front brake caliper from an older kawi laying in my garage and mount it to my 19 fork, i'd be willing to bet the house it'll fit.
Post a reply to: KX450F front caliper
